Te koop YAMAHA AV Receiver RX-V650
« Gepost op: 5 januari 2019, 11:01:10 »
Te koop: goed werkende YAMAHA AV receiver
Afstandsbediening + de afstelmicrofoon zijn aanwezig
VRAAGPRIJS 80 euro
Bij voorkeur op te halen, bij verzenden zijn de kosten voor de koper.
Specifications:
AUDIO SECTION
Minimum RMS Output Power for Front, Center, Surround, Surround back
20 Hz to 20 kHz, 0.06% THD, 8 Ω ...................................... 95 W
Maximum Power (EIAJ)
[General models]
1 kHz, 10% THD, 8 Ω ........................................................ 135 W
Dynamic Power (IHF)
8/6/4/2 Ω ........................................................... 130/165/195/240 W
DIN Standard Output Power [U.K., Europe and Asia models]
1 kHz, 0.7% THD, 4 Ω ....................................................... 145 W
IEC Output Power [U.K., Europe and Asia models]
1 kHz, 0.06% THD, 8 Ω ..................................................... 105 W
Damping Factor (IHF)
20 Hz to 20 kHz, 8 Ω ..................................................100 or more
Frequency Response
CD terminal to Front L/R ...................... 10 Hz to 100 kHz, 3 dB
Total Harmonic Distortion
CD, etc. to Front L/R (20 Hz to 20 kHz, 50 W, 8 Ω) .......... 0.06%
Signal to Noise Ratio (IHF-A Network)
CD (250 mV) to Front L/R, Effect Off ...............................100 dB
Residual Noise (IHF-A Network)
Front L/R ................................................................ 150 μV or less
Channel Separation (1 kHz/10 kHz)
CD (5.1 kΩ terminated) to Front L/R ....................... 60 dB/45 dB
Tone Control (Front L/R)
BASS Boost/Cut ........................................................ 6 dB/50 Hz BASS Turnover Frequency .................................................350 Hz TREBLE Boost/Cut ................................................ 6 dB/20 kHz TREBLE Turnover Frequency ...........................................3.5 kHz
Phones Output .......................................................... 150 mV/100 Ω
Input Sensitivity/Input Impedance
CD, etc. ................................................................. 200 mV/47 kΩMULTI CH INPUT ............................................... 200 mV/47 kΩ
Output Level/Output Impedance
REC OUT ............................................................. 200 mV/1.2 kΩPRE OUT ..................................................................... 2 V/1.2 kΩSUB WOOFER ........................................................... 4 V/1.7 kΩZONE 2 OUTPUT
[U.S.A., Canada and Australia models] ............ 200 mV/1.2 kΩ
VIDEO SECTION
Video Signal Type .......................................................... PAL/NTSC
Signal to Noise Ratio .............................................................. 50 dB
Frequency Response (MONITOR OUT)
Composite, S-Video ................................. 5 Hz to 10 MHz, 3 dB Component .............................................. 5 Hz to 60 MHz, 3 dB
GENERAL
Power Supply
[U.K. and Europe models] ................................. AC 230 V, 50 Hz [General model] ................ AC 110/120/220/230-240 V, 50/60 Hz
Power Consumption
[U.S.A. and Canada models] ................................. 400 W/500 VA [Other models] .................................................................... 440 W
Standby Power Consumption ................................................. 0.1 W
AC Outlets
[U.S.A., Europe and Canada models].. 2 (Total 100 W maximum)
Dimension (W x H x D) .................................. 435 x 171 x 420 mm (17-1/8 x 6-3/4 x 16-1/2)
Weight .............................................................. 12.5 kg (27 lbs 9 oz)
« Laatst bewerkt op: 6 januari 2019, 12:01:52 door Ruud Schouten »
